- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ethernet port aggregation?
- Mark as New
- Bookmark
- Subscribe
- Permalink
what is it? Can I use it for gaming?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://en.wikipedia.org/wiki/Link_aggregation
LAG is mostly used between the router and a device that supports LAG, like some NAS:
https://kb.netgear.com/29843/Port-Aggregation-with-Synology-NAS-on-your-Nighthawk-router
Since gaming consoles don't support LAG, gaming isn't supported on it.
On a gaming PC, might be possible:
https://www.pcgamer.com/how-to-set-up-nic-teaming-link-aggregation/
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ethernet port aggregation?
thanks for the info.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Game consoles aren't supported BUT if you aggregate your router and a compatible SWITCH that your console is connected to; the data will be sent and received 2x faster from your console.
- Mark as New
- Bookmark
- Subscribe
- Permalink
what switch should I get?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try NGs GS series...I believe you'll need a managed supporting kind of switch. Something to ask NG about.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
