Orbi WiFi 7 RBE973
Ethernet switch causing lag
Sorrow
Follower
Since I have installed my switch(GSS116E) I notice my connection is a bit more choppy depending on the device so the PS4pro can get really bad lag and since I mostly play fighting  games this is a problem I do have some of the consoles connected directly to my router and those seem to have no issue but that only has 4 ports and in my house we have a lot of devices I actually need to upgrade the switch to one with more ports soon, is there anyway to see if there is indeed lag being cause by the switch also is there a way to fix it?
Model: GSS116E|ProSafe 16 ports gigabits Click switch
Message 1 of 3
schumaku
Guru
Re: Ethernet switch causing lag
Very unikely the switch does add reasonable lag. Much more likley there are other devices on the other 14 ports causing traffic...
Message 2 of 3
Netduma-Liam
NetDuma Partner
I'd suggest posting this over in one of the sub-forums for Netgear switches, you should get the assistance needed over there!
Message 3 of 3
Discussion stats
  • 2 replies
  • 1344 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
