- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extreme gaming lag on raids.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extreme gaming lag on raids.
Is the XR router connected to the S8000 switch and your game device behind he switch?
What happens if you just connect the XR only with your gamimg device with out the switch in the mix?
IF others are seeing same thing in the game, possible this is a Mfr of the game and game service issue.
What happens if you disable QOS and Anti Buffer features on the XR router, save settings and reboot the router and modem?
What Fw version is loaded on the XR router?
Might narrow this down even farther and connect up your gaming device directly to the modem and test the game out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you say that other people in the raid have complained about the same problem, do you mean that they are experiencing the same lag on their end, or that they are noticing that YOU are lagging specifically?
If it's the former, it suggests it might be a problem inherent to the game itself and not something that can be fixed from your end. If it's the latter, then we can work out some settings to improve matters.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
All this gaming with your friends at your home and all connected to the same router or at different locations?
And if you connect your PC directly to the ISP modem and game there, no lag?
- Mark as New
- Bookmark
- Subscribe
- Permalink
We are all connected at our individual homes located in different states etc. We aren't all at my house.
I just removed the switch from the setup and connected the PC directly into the router. When I connect the PC straight to the modem I dont get internet access for some reason.
The problem is we only raid a few nights a week and the lag only happens at certain points on certain events when we are all burning and stacked on top of one another so its hard to test when I make changes outside of raiding hours.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also did a factory reset on the router and set the bufferbloat sliders back to 70. I inputed my PC as a console so it would show up on the Geo filter again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its weird that under autoping it will say the ping to the server is 25 but in the game its double that and says 50?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll need to power off the modem for 30 seconds then back on. Make sure your PCs netowrking configuration is set for auto obtain IP addressing. The PC will get a public IP address probably about a minute or two after the modem is online. This would help narrow this down to weather this maybe a game issue or router issue.
If others in your game group notice this as well from there locations, I would presume this is not a router issue, rather a game service issue.
You might contact the game Mfr and ask them about any information regarding this and see if they have any kind of information about router configurations if needed.
There are many factor in seen LAG, Can gome from services, other gamers, ISP services and speeds used. Users using wireless connections for gaming rather the wired. And router configurations as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It seems like my best dslreports bufferbloat readings and my lowest game lag and ping occurs when I have QOS and Antibufferbloat completely turned off on the XR500 and my S8000 switch set to 256out and 16in. I just don't get why I paid $350 for a router when I get my best readings with all of its functions turned off and the $80 switches functions turned on. Seems like I wasted $350 on a Netgear router when I should have kept my old Comcast router and just ran the S8000 $80 switch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wouldn't nessercarily trust the DSLreports stats on anti-bufferbloat. They're tuned to detect stuff like fq-codel, which is a commonly used anti-bufferbloat technique. DSLreports isn't tuned to detect the DumaOS anti-bufferbloat, which is an entirely different method that we developed in house.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I normally shut the modem down for 30 second when I switch the device connected to the modem.
As for speed or lag when others connect to your server at home they are using mostly your upload speed which is 40Mbps since your connection is 1024 Mbps Down and 40 Mbps Up.
In my experience with this router even if you have a Gig Speed connection this router will only go upto !/2 a Gigabit per second max.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
