× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Factor reset
Sidd44
Initiate
Factor reset
My xr1000 went into a factory reset last night. Has anyone experienced this before?
Message 1 of 3
Accepted Solutions
Guru
Re: Factor reset
I've seen device factory after firmware updates.
Did you update firmware or have it on auto-update?
Message 2 of 3
All Replies
Guru
Re: Factor reset
Message 2 of 3
Sidd44
Initiate
Re: Factor reset
I was thinking the same thing. Thanks for your input.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1291 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
