× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Firmware Version 1.0.1.50
Vger2
Hello everyone. I recently updated my Netgear Nighthawk Xr700 wireless router with Firmware Version 1.0.1.50. Did a direct firmware download and updated via wireless router interface. Having issues after reboot with wireless connectivity. Did a reboot of router again and OK for a time, but wireless connectivity issues keep coming back.
Should I reflash firmware over again? Thanks
Message 1 of 3
Guru
Re: Firmware Version 1.0.1.50
Before doing that, I'd try a factory reset and reinstall. If you're having issues after a firmware update, its usually the first step we try.
Message 2 of 3
Netduma-Fraser
NetDuma Partner
As above, always recommended to do a factory reset after a firmware upgrade, let us know if that resolves the issue for you.
Message 3 of 3
Discussion stats
  • 2 replies
  • 902 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
