Reply
Firmware flash
Jah1379
Firmware flash
Hi, has anyone figured out how to flash Duma OS software onto the X10?
The XR700 is the same router with the same specs
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 3
Re: Firmware flash
This does not mean that the firmware will flash.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
Netduma-Liam
NetDuma Partner
Re: Firmware flash
Thanks for your interest in DumaOS.
Unfortunately, I'm afraid you won't be able to flash XR700 firmware to an X10. The firmware is locked to the model that it was built for, so it  will only work if you're using an XR700.
Message 3 of 3
Discussion stats
  • 2 replies
  • 432 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
