× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Forgot Recovery Password
ChaiYang
Follower
I forgot my recovery password to login into my Nighthawk RX500 router?
What should I do to get into it?
Message 1 of 5
Netduma_Alex
NetDuma Partner
Re: Forgot Recovery Password
If you enter your password incorrectly 3 times, the router will enter the recovery process. You need to enter the router's serial and then answer the security questions you set.
If you can't remember the answer to the security questions, then you'll need to perform a factory reset using the button on the back. It's a small hole that you'll need a pen or a pin or something to press. Hold it for "up to thirty seconds"...
There's a guide here: https://kb.netgear.com/000053098/How-do-I-perform-a-factory-reset-on-my-Nighthawk-Pro-Gaming-router
Message 2 of 5
Netduma_Alex
NetDuma Partner
By the way, the serial is on the sticker on the bottom. Maybe take a picture of it.
Message 3 of 5
schumaku
Guru
Does the router continue to allow using the correct admin password, or can this be abused for some "fun" DoS?
Message 4 of 5
Netduma-Fraser
NetDuma Partner
What are you referring to @schumaku?
Message 5 of 5
Discussion stats
  • 4 replies
  • 1091 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
