- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Gateway Wifi Router to monitor wireless temperature sensor and send data to Azure Iot hub
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to send wireless pressure sensor data to azure IOT hub. For communiction between wireless sensor and Internet, I am looking for gateway Wifi router which can act as access point as well as station and easily create the wifi hotspot with smart phone also.
I want to design a cross platform appliction which will be able to display the values on smartphone by receving the message from gateway router as well as can also use the Azure Database.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Gateway Wifi Router to monitor wireless temperature sensor and send data to Azure Iot hub
Are you looking for a modem with a built in router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey, Thanks for the reply
Yes, I am looking for the modem with IEEE 802.15.4 standard built-in with the router
Does The router You have mentioned use the XBEE devices?
Or should I have to use connect Receiver modem with this kind of router to receive the value?
