- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Geo-Filter not working after reset on XR1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I had to perform a reset on my XR1000 as it would not assign an ip address to my Xbox console. Since I have reset the router some features are not functioning correctly. I am unable to use the Geo-Filter at all, it is giving me an error of which I will attach a screenshot. I have the most up to date firmware. Any advice would be greatly appreciated. Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would start by trying to work out why that happens. There is a chance that the thing that caused this issue has also resulted in what you see now. Resetting just gets you back to square one.
Start with answers to the usual boilerplate questions.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting. It can also cause the problem with the Xbox that got you here in the first place.
Finally, the XR1000 is not one of the routers covered in this section of the community.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Support | NETGEAR
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Geo-Filter not working after reset on XR1000
