× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Geofilter not working on pc
GLitchGlenn
Initiate
Good Day. Coming from ps4 to pc since a week. I was hoping that my xr500 would work the same way like i had it on my
Ps4 with setting regions to block out other countries that are known for pooor connections etc. But i add my pc to geofilter but it doesn't show anything. i looked thru some other posts but i cant get it going. i added pc and set that to Destiny pc(yes i play that 🙂
But i cant get it work at all. would be great if i could set my zones on pc aswell since my main game uses p2p.
thanks in advance
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 3
Netduma-Fraser
NetDuma Partner
Re: Geofilter not working on pc
In the Device Manager change the Device Type of the PC to an Xbox or PlayStation then remove the device from the Geo-Filter and re-add it. Does it work then?
Message 2 of 3
GLitchGlenn
Initiate
yes it did. thank you very much for great support. had no idea i could do that. many many thx
Message 3 of 3
Discussion stats
  • 2 replies
  • 927 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
