× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Geofilter
del3213graphix
Geofilter
I just got my xr500 and in the Geofilters my game isnt listed? Is there anyway to add my game? Doom2016? Also i notice there something to select Unreal Engine which doom2016 is based off of but no servers still come up?
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 2
Netduma_Jack
NetDuma Partner
Re: Geofilter
Hi there - Doom 2016 uses id Tech 6 game engine so choosing Unreal Engine will not work. But there is a workaround:
Go to Device Manager
Click on your PC
Change you device type from a computer to an Xbox
Go to the Geo-Filter
Delete your PC from the top panel if it's already in there
Now add your PC again
Servers etc should now show. However, we have not tested how the game responds to the Geo-Filter, so tread carefully. You may just want to use Spectating Mode initially as this will show server location and ping, before then trying Filtering Mode.
Message 2 of 2
Discussion stats
  • 1 reply
  • 1192 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
