wait_i-m_low's avatar
Mar 29, 2019
Geofilter
Hallo!
Is there a possibility to adjust the geofilter beneath 69 miles. On my router it’s absolutely not possible .
  • FURRYe38's avatar
    I presume no. Would be no reason for a small size. Networking wise would be difficult possibly to connect with others.
  • This is an enforced limitation. What's the reason you want to go even lower?
    • wait_i-m_low's avatar
      wait_i-m_low
      Guide
      I want to play private matches with 2 PlayStation at the same network. I thought it’s the easiest solution with the Geofilter. Or are there different ways 🤷‍♂️
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        You can usually do this on the game itself by selecting LAN or local rather than online/multiplayer. You shouldn't need the Geo-Filter to achieve this.
