× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Gigabit wifi speeds halved on XR1000
Mustang1313
I'm sure that this topic gets touched on a couple of times a month at this point, but I cannot find a working solution to this issue. I just moved to a new house and we upgraded to gigabit download speeds. The issue is that my network download speeds seem to max out around 450mb/s. It does not appear to be the modem (which does not have router functionality), as I have tested the ISP provided router which provides 900mb/s at a minimum on wifi and ethernet.
Things that I have tried:
- Factory Reset router
- Disabling QoS as well as resetting distribution, Traffic meter, and congestion control (this did briefly bring ethernet speeds to 900, before returning to 400s)
- Manually setting expected speeds
- Removing all other devices on the network
- Using ethernet (Cat-6)
- Switching Wifi Channels and checking for interfering networks
- Updated to most recent firmware
All of the above were tested at a time that internet congestion would be at a minimum.
Clearly, there is still a setting that I am missing since speeds to the router are at least 900, and the router should theoretically be capable of over 4Gb.
If anybody out there has a fundamental understanding of DumaOS and this router, I would greatly appreciate your insight.
Message 1 of 6
Guru
Re: Gigabit wifi speeds halved on XR1000
What devices are you using for speed testing?
Are you getting to spec speeds at the ISP modem or ONT with out the router connected?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What configurations are set under Advanced Settings/Advanced/Advanced Wireless?
Make sure the MIMO and Beamforming are enabled.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-...
WiFi Speed Info:
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
(old link with re-direct to new site URL)https://www.duckware.com/tech/wifi-in-the-us.html
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
Message 2 of 6
Netduma-Fraser
NetDuma Partner
Good questions above, also where are you testing the speeds?
Message 3 of 6
Mustang1313
I'm testing using the downloaded speed test.net app on my computer and phone located maybe 4 feet from the router. Getting the full speed straight from the modem, yes.
Firmware: XR1000V2 1.1.0.16_2.1.25
Modem: Spectrum DOCSIS 3.1 eMTA
I am using CAT6 cables and set the channels to the ones you recommended.
So far it's still in the 400 range. Please let me know if you have any other ideas!
Message 4 of 6
Mustang1313
I should clarify: Ethernet speed has improved to 900
5G signal has not improved at all.
I've checked wifi and there is no interfering signal in my area.
Message 5 of 6
Netduma-Fraser
NetDuma Partner
Do you have Smart Connect enabled or disabled?
Ensure the router is in an elevated position - not on a metal surface
Ensure there aren't any electrical / wireless devices e.g headphones etc within close proximity ~3 feet if possible
Set the antennae to this position _ | | _
Then see if that improves it. What is the device you're testing the WiFi speeds on also?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 492 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
