× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Help on XR500 PS4 Fifa 19 setup lag (100ms ping)
Alvarommb
Guide
I need help with my xr500 setup for Fifa 19 on PS4, no matter what I do I always have 100ms ping or above, I have try:
upnp on/off
DMZ on/off
Quos 75%\85%\95% & on/off
TP 95%\90%\85% for the PS4 on down/load
Geo filter on/off
Auto ping on/off
My isp modem is on bridge mode, 60mb down, 6mb load, all hardware is wired through utp6 cables, just don’t know how to get lower ping
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 10
Alvarommb
Guide
Re: Help on XR500 PS4 Fifa 19 setup lag (100ms ping)
I also get disconnected from some matches randomly
Message 2 of 10
Netduma-Fraser
NetDuma Partner
Where do you live and what servers are you connecting to?
Message 3 of 10
Alvarommb
Guide
Hi, I live in Peru, and Mostly I get connected to Brazilian servers, but sometimes to mexico’s And US servers also
Message 4 of 10
Netduma-Fraser
NetDuma Partner
That is probably to do with it. If you do a speedtest.net test to the closest server when nothing is using the internet what ping do you get?
Message 5 of 10
Alvarommb
Guide
O will try that and post the results
Message 6 of 10
Alvarommb
Guide
On the browser of my PS4 I get 25 ms ping to closest server which is my isp server, I’ve try changing my location to Mexico and I still have +100ms ping but the game is much more fluid
Message 7 of 10
Netduma_Jack
NetDuma Partner
That's quite a high base ping, but I'm happy you are having a better time on the Mexican server. I've seen that before on FIFA - I know a famous FIFA player (Krasi) prefers the Dutch server over the German server as it's smoother for him.
Message 8 of 10
Alvarommb
Guide
I would try different locations then, do you know if there are some kind of guide/link for the basic setup of the dumaos for PS4? Because I can’t find anything like that
Message 9 of 10
Netduma_Jack
NetDuma Partner
I'd recommend working your way through these optimal settings guides for each feature you want to configure. Each guide won't take long to follow: http://support.netduma.com/en/support/solutions/folders/16000090646
Message 10 of 10
Discussion stats
  • 9 replies
  • 4017 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
