Reply
Help with tweaking my QOS Bufferbloat Ping.
moose1111
Tutor
Everthing is set 1000 up and 1000 down from verizon Fios. I do have both slider at 70%. Also I have my Sony TV AND Gaming PC Bandith set to 50 both up and download. Everthing else is set as should be thanks to You Tube. lol. Anyways with MY OCD I would like to get my pings especially Bufferbloat ping lower which results are fro DSL Reports. As of my last results are as follows. Download 494.6 and upload is 494,2 OVERALL Is an A+ Quality is an A+ and BUFFERBLOAT IS  AN A I know which is good but when i click on the  Shar Results these are the results.
IDEL hIGHEST PING 8MS AND LOWEST IS 4MS
Download is  HIGHEST 16MS LOWEST IS 13MS I FEEL is high again might be OCD. LOL
UPLOAD IS HIGHEST IS 14 ms and lowest 13ms, I feel this is to high especially for competive gaming.
Thanks for all your help in advance.
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 3
Netduma-Fraser
NetDuma Partner
Re: Help with tweaking my QOS Bufferbloat Ping.
I would not pay attention to DSLReports. Bufferbloat only occurs when your network is saturated. At your speeds and with QoS enabled you will not see this problem. That is not high in the slightest, to give you an idea 5ms is about what you'd get playing on LAN. You have a very good ping, nothing to worry about.
Message 2 of 3
moose1111
Tutor
Thank you Sir
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 837 views
  • 1 kudo
  • 2 in conversation
Announcements
