× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Here we go again
Rick6922
Luminary
Here we go again
just updated my xr700 to new fireware about an hour ago. will not stay conected to the xbox1x AGAIN.... [UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP set event: del_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:48 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Sunday, January 13, 2019 13:44:47 [DumaOS] DHCP lease change., Sunday, January 13, 2019 13:44:47 [DumaOS] DHCP new event., Sunday, January 13, 2019 13:44:47 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, January 13, 2019 13:44:47 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Sunday, January 13, 2019 13:44:45 [DumaOS] DHCP lease change., Sunday, January 13, 2019 13:44:45 [DumaOS] DHCP new event., Sunday, January 13, 2019 13:44:45 [LAG] Active lag now, Sunday, January 13, 2019 13:44:42 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, January 13, 2019 13:44:32 [Internet connected] IP address: 24.95.165.47, Sunday, January 13, 2019 13:44:20 [Internet disconnected] Sunday, January 13, 2019 13:44:18
Model: XR700| Nighthawk Pro Gaming Router
Message 1 of 34
Accepted Solutions
Rick6922
Luminary
Re: Here we go again
i fiqured it out, thanks to all that responed!
Message 33 of 34
All Replies
Rick6922
Luminary
Message 2 of 34
Rick6922
Luminary
[UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP set event: del_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:48 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Sunday, January 13, 2019 13:44:47 [DumaOS] DHCP lease change., Sunday, January 13, 2019 13:44:47 [DumaOS] DHCP new event., Sunday, January 13, 2019 13:44:47 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, January 13, 2019 13:44:47 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Sunday, January 13, 2019 13:44:45 [DumaOS] DHCP lease change., Sunday, January 13, 2019 13:44:45 [DumaOS] DHCP new event., Sunday, January 13, 2019 13:44:45 [LAG] Active lag now, Sunday, January 13, 2019 13:44:42 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, January 13, 2019 13:44:32 [Internet connected] IP address: 24.95.165.47, Sunday, January 13, 2019 13:44:20 [Internet disconnected] Sunday, January 13, 2019 13:44:18        is this styem log saying its deleting the nat rule?  if so  whats that mean?
Message 3 of 34
Netduma-Fraser
NetDuma Partner
It's frequently renewing LAN IP address for the device. Set a static IP for the device and also set a static WAN IP for the router itself
Message 4 of 34
Guru
Is Instant ON enabled on the console? If it is, disable it.
Message 5 of 34
Rick6922
Luminary
no its off. lol
Message 6 of 34
Guru
Do you have a IP address reservation set for the game console? This is recommended.
Is the console wireless or wired to the router?
Beamforming enabled. Disable MIMO. IF you see Fast Roaming or 802.11k, disable this. Maybe found under router IP/debug.htm
What MFr and model# ISP modem is the XR router connected too?
Message 7 of 34
Rick6922
Luminary
I have the ips reservation . I went through all that the first time. my modem is the NG cm1000. the other things you sugested i dont know how to do.It was working fine till i upgraded to new fireware .
Message 8 of 34
Rick6922
Luminary
its wired.
Message 9 of 34
Rick6922
Luminary
[DoS Attack: ACK Scan] from source: 199.16.156.58, port 443, Sunday, January 13, 2019 15:36:04 [DoS Attack: ACK Scan] from source: 199.16.156.75, port 443, Sunday, January 13, 2019 15   DO YOU NO WHAT THIS MEANS IN THE SYSTEM LOG?
Message 10 of 34
Guru
When you did the FW update, did you download the FW file then apply it then continue? Or did you do a factory reset and setup from scratch? You might do a factory reset and set up from scratch.
 I would power OFF the modem for 30 seconds then back on, then do the factory reset and setup from scratch.
Don't worry about the suggestions for wireless I meantioned. That would be if the console was wireless connected.
If after doing the reset and setup from scratch doesn't solve this, I would revert back to prior working FW version.
See reply here:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/does-anyone-no-what-this-means/td-p/16...
Message 11 of 34
Rick6922
Luminary
I tryed doing a factory reset , but after the setting ,password  dumuOS settings was still there like it didnt reset.
Message 12 of 34
Guru
Was the reset done with the back button or thru the routers web page? I like using the web page...
Ensure you clear out all browser caches after triggering the reset as well, exit the browser then re-launch it.
Try using IE11, FF or Opera.
Message 13 of 34
Netduma-Fraser
NetDuma Partner
WAN and LAN reservations? If it occurred when upgrading to the new firmware go back to the old firmware and see if the issue occurs again please. Also disable IPv6 in Advanced Settings.
Message 14 of 34
Guru
When you do a reset and setup from scratch, I would also change the default LAN IP address pool to 192.168.1 100 to .150 or .200.
Then set up IP address reservations for your devices and the xbox.
I would also do a hard reset on the game console as well. Hold the power button on the front untill it shuts off. Do a IP address reservation on the router, save changes then reboot. Then power ON the xbox.
Message 15 of 34
Rick6922
Luminary
OMG, did a factory reset and router wouldnt let me back in. finily got in but i had already set ip last # to 250. already did those things, look at the system log........................6 [DumaOS] Marking device that is marked 192.168.1.6 5 2., Sunday, January 13, 2019 17:41:20 [Internet connected] IP address: 24.95.165.47, Sunday, January 13, 2019 17:40:40 [Internet disconnected] Sunday, January 13, 2019 17:40:38 [DumaOS] Marking device that is marked 192.168.1.6 5 2., Sunday, January 13, 2019 17:39:21 [Internet connected] IP address: 24.95.165.47, Sunday, January 13, 2019 17:38:40 [DumaOS] Marking device that is marked 192.
Message 16 of 34
Rick6922
Luminary
i just type the ip address into the xbox to do that on the xbox right?
Message 17 of 34
Rick6922
Luminary
for the static part on the router I dont no how to do.
Message 18 of 34
Rick6922
Luminary
in the wan setup theres no option for static
Message 19 of 34
Rick6922
Luminary
by pushing a pin in the little hole in the back of the router
Message 20 of 34
Guru
No, set a IP address reservation ON the router.
Message 21 of 34
Guru
Just leave the WAN at Dynamic. Unless your ISP supports giving there customers Static IP addresses, which most don't, leave the router Dynamic DHCP.
Message 22 of 34
Rick6922
Luminary
when I look at my log files on router it says internet disconected all the time. if you look in the nighthawk gaming router forms .theres other people posting the same issue.
Message 23 of 34
Rick6922
Luminary
LOOK AT MY LOG FILES,EVERY TIME IT DISCONETS FROM INTERNET I GET LOGGED OUT OF XBOX LIVE...................................... [DumaOS] DHCP new event., Monday, January 14, 2019 07:15:34 [Internet connected] IP address: 24.95.165.47, Monday, January 14, 2019 07:15:09 [Internet disconnected] Monday, January 14, 2019 07:15:07 [
Message 24 of 34
rxman4453
Guide
Firmware 1.0.1.2 and 1.0.1.8 are not stable.  WAN/Internet drops are prominent.  Only workaround that I have found is to just downgrade to 1.0.0.20.  It is a stable firmware version.
Message 25 of 34
Discussion stats
  • 33 replies
  • 6554 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
