- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How do I communicate with my modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a modem on the other side of my XR1000. The XR1000 replaced an old Asus router, which allowed me to talk right through it to the modem. Think is the XR does not. It was a really handy feature to have! Can anyone tell me how to talk through the XR? I need to change a few settings for the XR1000 in the modem itself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How do I communicate with my modem?
Its a Draytek 130. The modem is 192.168.2.1 and the router is 192.168.1.1
As I said before, with my old Asus router this worked.
I seem to remember I had a different Netgear router years ago and that, too, failed to pass on messages to the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello and thank you for the suggestion.
Alas not, same result as before - nothing. I am wondering if this needs ports or something?
- Mark as New
- Bookmark
- Subscribe
- Permalink
you're on a different subnet.
Try reading this thread a bit. I haven't ever needed to modify mine so I can't test it with my current setup because I'm on cable. But this is for using the same vigor modem
https://www.snbforums.com/threads/how-to-access-wan-modem-from-lan-with-different-subnet-mask.29468/
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also note that the upnp configuration does not work. If I set it to enabled, it doesn't stay that way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I checked out the subnet mask and it is correct. I have no idea why I can not commicate with the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you put the Draytek in bridge mode or anything like that or is it still acting like a router? The UPnP checkbox is currently bugged but is enabled by default so youcan ignore that if it appears otherwise.
