Orbi WiFi 7 RBE973
Reply
How do I set up 2 xbox's using seperate live accounts on a xr500?
kc717
Follower
Looking for a way to connect 2 xbox one's using separate live accounts to e able to play online games at the same time.  Using a XR500 with updated frmware.
Thank you
Message 1 of 3
Guru
Re: How do I set up 2 xbox's using seperate live accounts on a xr500?
Just connect them. WIred or WIreless. Refer to the MS or xbox support pages for help and information on connecting game consoles to the router.
I recommend setting NAT Filter to OPEN on the XR router. Under Adavanced tab/WAN Setup.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
Message 2 of 3
Netduma-Fraser
NetDuma Partner
They can play at the same time, that's no problem, is there something you're specifically wanting to do with them?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 681 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
