Discussion stats
  • 7 replies
  • 434 views
  • 3 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
How to Use it
So I have some questions. Before buying the router, I'd like to hear some experienced inputs from you guys.
1. When connecting console (for my case, PS4 Pro) to the Pro Gaming router XR500, after configurating with the software, do I have to leave the laptop on from now on while using it or I could just put my laptop to sleep and the router will do its job? I'm a bit confused on this part.
2. I have Netgear Orbi (RBK50), for those of you who also have Orbi, what do you suggest I should do?
Thank you!
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 8
Highlighted
Guru
Re: How to Use it
You don't have to leave any PC or laptop on while managing the router. ONce your done you can log out of the routers web page. You can leave the laptop ON or off. Up to you.
You can use the Orbi in AP mode connected to the XR router. Disable the XR routers wifi radios and use the Orbi as your wifi mesh system. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Thank you!
My Setup (Cable 900Mbps/50Mbps)>CAX80>Orbi RBK50 v2.5.1.16(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK50/RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 8
Highlighted
Re: How to Use it
For answer #1, thank you! I'll keep that in mind!
for #2, so would this mean I could still be able to use Wifi while setting it in AP mode? I was thinking of turning off Wifi on the XR500, but leave Wifi on Orbi, so you're suggesting I should set it in AP Mode then?
Message 3 of 8
Highlighted
NetDuma Partner
Re: How to Use it
You could leave the orbi in it's usual mode and just put the orbi's IP address into the DMZ of the XR500, then turn off the wi-fi on the XR500... Maybe that's wrong? Let me know @FURRYe38
Message 4 of 8
Highlighted
Guru
Re: How to Use it
Yes, you can use the ORbi in AP mode and configure the WiFi normally. If you use the Orbi in AP mode, you don't need to use the DMZ on the XR router.
Message 5 of 8
Highlighted
Re: How to Use it
curious, wouldn't the QoS on Xr500 affect Orbi though?
Message 6 of 8
Highlighted
Guru
Re: How to Use it
Only for those devices that QoS was managing. Same would be if you had the radios enabled on the XR and not using the Orbi. Your just exhanging the wifi radios on the XR for the Radios on the Orbi is all.
Message 7 of 8
Highlighted
NetDuma Partner
Re: How to Use it
Would the mesh continue working in that situation? I was considering turning my google wifi into an access point but apparantly that removes all mesh functionality from them, according to google anyway.
Message 8 of 8
