× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How to create hidden network on XR300
Tlapts
Follower
Is there a way to turn my XR300 WiFi SSID's into hidden networks?
Thanks
Ed @ tlapts3527@gmail.com
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 3
Guru
Re: How to create hidden network on XR300
You might see if there is a disable SSID broadcast feature under advanced settings. If not, then the SSID can't be hidden.
Message 2 of 3
Netduma-Fraser
NetDuma Partner
As above, that is the only way you could do it.
Message 3 of 3
Discussion stats
  • 2 replies
  • 701 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
