droesw's avatar
droesw
Guide
Dec 02, 2019
How to setup VPN on XR500?
I just bought a subscription for NordVPN to use with my XR500 router. Is there any way someone can post a list of all the steps needed to set it up on the router, because I'm a little confused about it.
Also, do you know if using a VPN will affect my latency at all? I'm unsure what to believe, because some things online say it will increase ping and others say it will decrease it.
