- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Hybrid VPN Setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Hybrid VPN Setup Guide
In regards to your DNS leak you might want to consider Cloudflare (1.1.1.1) for your primary DNS-see why at the following link: https://www.cloudflare.com/learning/dns/what-is-1.1.1.1/. VPN providers will often provide there own DNS server but it usually has a negative impact on performance when installed on the internet setup page of your router. Just a suggestion for the interim.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have it setup and working but my problem is when I turn the vpn on I get double Nat on the Xbox. It’s only when the vpn is on. Not sure what is causing this?
Thanks for your help
Luke.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a subscription to HideMyAss vpn and using that for my Hybrid VPN connection. The only connections I have to Hybrid VPN is 2 PS4's. When the VPN is on and says connected I can not access any games on the PS4. When I turn the VPN off I have no issue connecting to games. Please help !!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has anyone got IPVanish VPN to work with the XR500?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The configuration files for ipvanish can be found here:
https://www.ipvanish.com/software/configs/?_ga=2.61144676.939145539.1599761612-1299560907.1599761612
Download configs.zip to download all the available config files or pick the one that is best (closest) to your physical location:
https://www.ipvanish.com/software/configs/configs.zip
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I need big help trying to figure out setting up my vpn with the xr500 I spent 5 hours last night trying to get it to work and I’m completely lost. I am not a networking guy at all. I tried my best but you all got me confused as hell with this download the config file and all that. Lol. I need help. I am going to provide a screenshot of the instructions I think I’m supposed to use and my current situation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I'm trying to connect a hidemyass VPN and in your instructions it says to toggle disable then add sign in details for hidemyass, then says to enable before connecting. That option isn't possible for me, can you help please?
Joe
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you know if this feature will be coming to the XR1000. Only VPN option i see is under the advanced settings and that would apply to the whole network.
I would like to only apply it to specific devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The VPN in Settings is a VPN service so you can connect to the router from somewhere else. Don't have an estimate for Hybrid VPN, that's up to NG.
- « Previous
- 1
- 2
- Next »
User | Count |
8 | |
4 | |
3 | |
1 | |
1 |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
