- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Hybrid VPN Torguard on Nighthawk xr500
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Hybrid VPN Torguard on Nighthawk xr500
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
To allow me to retest/get screenshot - can you answer these questions? This is the Torguard config generator page - questions - which 'os' should I select? which version of OpenVPN for this router? Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, I'm running Apple devices. Is this setting likely to interfere with this stuff?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Ran a new test to get a screenshot. I have triple checked the protocol and port of the config. I have run countless whatismyip and portchecker.co checks and all show that this config does absolutely nothing in terms of the VPN connection. All checks show my regular WAN IP and that the supplied port (32400) is closed despite it being open on the VPN IP (through Torguard site).
Additionally, this is using the first os and OpenVPN v '2.4 and above'.
- Mark as New
- Bookmark
- Subscribe
- Permalink
More findings.
I have a feeling I'm missing something here. Upon further testing when I have the mode of the Hybrid VPN set to 'Do not VPN these services' with an advanced setting of xxxxx port for all entries, my public IP *does* change to the VPN IP, however, that xxxxx port which is open on the VPN is closed/stealth with this mode active on the router.
Appreciate it if you can tell me what I'm missing!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do NOT VPN these services will VPN the entire device if you have no services added.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. We have a disconnect here somewhere. Let me fully explain what I'm testing/trying to accomplish/expecting.
I think I said that with 'Do Not VPN...' no port, I get a changed WAN. That is my expectation. However, this is the reverse of what I want to accomplish. When I set to 'Only VPN..' with xxxxx, there is no change in WAN as expected, but when I test xxxxx on VPNIP I get closed/stealth when the port is open through the VPN....
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
