Orbi WiFi 7 RBE973
Reply
I'm tired of blocking servers
josephquake
Tutor
I cannot block the servers that I do not want to connect in real time because it takes too long to show me the information I bought the router to have a good time I am all the time disconnecting myself from the games and blocking servers that I do not like if they could show me the information in real time it would be solved the problem I have to connect to the game that I do not want since it takes so long once inside it just shows me the server information
no puedo bloquear los servidores que no quiero conectarme en tiempo real porque tarda demasiado en mostrarme la informacion yo compre el router para pasarla bien estoy todo momento desconectandome de las partidas y bloqueando servidores que no me gustan si pudieran mostrarme la informacion en tiempo real se solucionaria el problema tengo que connectarme a la partida que no quiero ya que tarda tanto una vez a dentro recien me muestra la informacion del servidor
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 10
Netduma-Fraser
NetDuma Partner
Re: I'm tired of blocking servers
You don't need to block servers manually at all. All you need to do is set your radius and then it will block anything outside and allow everything inside automatically.
Message 2 of 10
josephquake
Tutor
I don't know why it gave me so much trouble
Message 3 of 10
Netduma-Liam
NetDuma Partner
Have you tried setting up Geo-filter as Fraser suggested?
That will automatically block most of the bad servers you could connect to and drastically improve your experience.
Message 4 of 10
josephquake
Tutor
what is fraser?
Message 5 of 10
Netduma-Fraser
NetDuma Partner
That's me and Liam is referring to what I wrote previously.
Message 6 of 10
josephquake
Tutor
I already did that of putting assist pin 20 and I put the geofilter of the atrantic ocean
Message 7 of 10
Netduma-Fraser
NetDuma Partner
I wouldn't suggest doing that, it is very restrictive and based on your location/where the closest servers are in relation to you, your base ping etc you may not even be able to get a ping that low. I would suggest using the radius instead and putting Ping Assist to 0.
Message 8 of 10
josephquake
Tutor
I am still finding games with low ping but there are 20% that are thrown at me on Brazilian servers that I do not want even with ping 150 the problem is especially when I try to play together with my brother with low ping and they almost always throw us to Brazil when they could perfectly launch to Chile you need to fix that we are both with the same geo-filter
Message 9 of 10
Netduma-Liam
NetDuma Partner
What are your current configurations? Are you still using just ping assist?
Message 10 of 10
Discussion stats
  • 9 replies
  • 2421 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
