× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
I ordered the Nighthawk AC2300 R7000P, but reveived the AC2400. Which router is better?
manloz
Tutor
Hello, I recently bought a new router since it has been 5 years since I bought my last.
I ordered the R7000P, but I received the AC2400 instead. I compared them both on the website, but I am not too savy with the terms or posted information. Can anyone provide some insight?
Thank you.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 4
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: I ordered the Nighthawk AC2300 R7000P, but reveived the AC2400. Which router is better?
Hi there, it would probably get you better answers if you were to post here for the router you have: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Message 3 of 4
All Replies
manloz
Tutor
I should have prefaced that I plan on returning it regardless, but I was curious. If the AC2400 is better, I'll simply cancel the R7000P order and order the AC2400
Message 2 of 4
Netduma-Fraser
NetDuma Partner
Message 3 of 4
manloz
Tutor
Thank you, I'll post it there.
Message 4 of 4
Discussion stats
  • 3 replies
  • 1470 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
