Orbi WiFi 7 RBE973
Reply
In Game Latency
Tkbuc
Guide
In Game Latency
Hi everyone,
Attached is a screenshot of in game latency details for an online game.  I just factory reset my router and have a 1GB modem via Spectrum.  Everything is working great.  Every once in a while my Latency will shoot up to 800 but then go back down to the 60/70/80 range.  It's doesn't happen consistently or frequently, but I'll notice it every once in a while.  I thought it is because I am using Bitdefender VPN so I turned it off but it still happens occasionally.   Is that normal to happen every so often?  Can anyone tell me what the data in the screenshot is telling me as I'm not that familiar with the readings?
Message 1 of 7
Guru
Re: In Game Latency
Not much to go off here.
Is this regarding a NG product? If so, need more details here.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Message 2 of 7
Tkbuc
Guide
Re: In Game Latency
Im using the Nighthawk XR1000.  The screenshot is the ingame latency data from the game client.
Message 3 of 7
Guru
Re: In Game Latency
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are you wired or wireless connected to the router? Wired is preferred for gaming.
Message 4 of 7
Netduma-Fraser
NetDuma Partner
Re: In Game Latency
Are you using QoS? If so could you provide a screenshot of the QoS page please? It could be a local congestion issue.
Message 5 of 7
Tkbuc
Guide
Re: In Game Latency
  1. Firmware Version 1.0.0.64
  2. Wired Connection with CAT 6
  3. Not using QoS
  4. Hitron Modem
  5. Model EN2251
  6. Spectrum is my ISP
Message 6 of 7
Netduma-Fraser
NetDuma Partner
Re: In Game Latency
Not using QoS is potentially the issue, use QoS and see if the issue persists
Message 7 of 7
Discussion stats
  • 6 replies
  • 852 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
