- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Internet Down Nighthawk XR500
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all, I write to you with troubles. Our Nighthawk XR500 suddenly just doesn't work anymore. The internet light just flashes orange. We reset the modem and the router several times. I even did a factory reset on the router and it seemed to work again... for a few hours that is. Same issue. I don't really even trust it anymore. Any chances you had a similar problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Internet Down Nighthawk XR500
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
