Cjw743's avatar
Cjw743
Tutor
Jun 22, 2023
Internet being hacked
I have the nighthawk xr1000 router with spectrum internet, is it likely that my internet could be hacked and how can I find out if it is or isn't. I ran a virus scan on my Mac and nothing showed up but I don't know how to check my internet to see if its been hacked or anything.
    • Cjw743's avatar
      Cjw743
      Tutor
      I just get paranoid a lot and I my internet speeds are sometimes weird at night but I know it's prob due to congestion but I just want to make sure nothing is get hacked. I don't really have the money to buy netgear amor right now so I don't know any other ways to check. Is there like common issues that I could spot when a router gets hacked?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        It's very hard to give an answer for that, it depends what kind of thing they're doing and in most cases, symptoms would likely present themselves on devices rather than the router itself. For example, PC appearing to be controlled without your input, viruses, dodgy software being downloaded etc.
