Orbi WiFi 7 RBE973
Reply
Internet issues with Netgear XR500
Azurtri
I started having an issue this weekend with my Netgear XR500 router. The issue is that it seems like the router is constantly dropping connection or something. I have a fiber connection that is 1 gig download and upload. When running a speed test with the router I get 1 ms ping and the correct speeds but several devices like tv's struggle to watch videos and while playing world of warcraft my ping is jumping up over 1000 and sometimes over 2000 and it makes everything appear to be moving in place for a few seconds then it will all catch up quickly. If I bypass the router on the PC alone, my ping in world of warcraft drops to 63 and all the issues go away immediately.
The first thing I tried was restarting programs on the PC and even rebooting the PC thinking it was on that end but when I continued to see issues with voice dropping in discord too I felt like something else was going on. I did the reboots of my ISP ONT and of the router multiple times. I tried swapping the ethernet cable between the ONT and router in case this may have been shorting out, tried 3 different cables. I eventually hard reset the router and set it back up along with making sure firmware was completely up to date. After all of this I am seeing the same network issues when connected through the router.
Being that world of warcraft is running smoothly along with discord and youtube at the same time while hardwired directly to my ONT it is quite clear something with the router is causing the issue I just don't know what. I really don't want to buy another router as this one is less than 2 years old but at this point I am not sure what else to try.
ONT is a Nokia GPON ONT I-010G and when directly connected to that I have no lag issues. I tried disabling QoS and Geo filter completely which helped for a day or so but now back to having issues.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 4
Netduma-Liam
NetDuma Partner
Re: Internet issues with Netgear XR500
Sorry to hear you're having these issues! Could you please let me know what firmware version you're currently running? When did you begin noticing these issues? Were there any changes to the environment around this time?
Message 2 of 4
Azurtri
I am running V2.3.2.114, I did run an update after hard resetting so not sure what it started as but started having the issue Friday. Small update, I decided to try my PC on wireless just to see if anything with the ethernet ports could be causing this. Wireless solved the issue as well so it is something stemming from the ports on the router. I did try multiple ports and I cleared the ethernet cable as the same cable direct to my ONT was fine. Any thing I could do to try and fix the ethernet ports or am I best off staying wireless at this point? I do take a speed hit but worth it if it fixes the lag.
Message 3 of 4
Netduma-Fraser
NetDuma Partner
I would recommend upgrading to this latest beta firmware which includes fixes for disconnects, then do a factory reset and see if it is more stable https://www.dropbox.com/s/4mwe5sx81gsc129/XR500-V2.3.2.114-DumaOS3.0.203.img?dl=0
Message 4 of 4
Discussion stats
  • 3 replies
  • 1596 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
