Reply
Invalid Serial Number for plex and amazon cloud
Pablo_Chirinos
Initiate
Hi, just wondering how to get my compliment Plex pass with the purchase of my new nighthawk xr700. When clicking on the "click here" I get invalid serial number.
Thanks in advance
Model: XR700| Nighthawk Pro Gaming Router
Message 1 of 4
Netduma-Fraser
NetDuma Partner
Re: Invalid Serial Number for plex and amazon cloud
Hi Pablo, if the router is completely new (if bought second hand it may have been used), then I would recommend contacting Netgear support directly as they'd need to generate a new number for you to use.
Message 2 of 4
Pablo_Chirinos
Initiate
Its new... Thank u
Message 3 of 4
Altsai
NETGEAR Expert
You may contact NTGR support team with your S/N# so that your unit will be granted to assign the promotion code accordingly.
by the way, I think the promotion code won't be able to be used for plex pass.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 725 views
  • 1 kudo
  • 3 in conversation
Announcements
