× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Issue with content filtering
Steinmeg
Star
Have the XR1000, trying to block you tube but not having any luck. Can access it from all devices. I added the rule, tried to hit site after I applied it and it was still active, then also tried after a reboot. I mean seem pretty straightforward, is this any known issue for this site? Could this be because I use cloudflare dns? Would not think that would have anything to do with it, even tried to just block Facebook for fun and still able to access it.
Model: XR700|Nighthawk Pro Gaming Router
Message 1 of 5
Accepted Solutions
Netduma-Liam
NetDuma Partner
Re: Issue with content filtering
OK, that might work as a good work around until NETGEAR can release a fix for their Content Filtering feature. Perhaps if you let us know your use case we can help you fine tune it a little further? For example, if you're trying to stop a particular device accessing YouTube after a particular time in the evening you could implement that to.
Message 4 of 5
All Replies
Netduma-Liam
NetDuma Partner
As far as I'm aware there's a known issue with Content Filtering not working, though it's a features of NETGEAR's settings and here at Netduma we don't have control over their settings.
Could you try adding a new rule to traffic controller for the device you want to block, then select 'Media' from the categories menu and see if that works better?
Message 2 of 5
Steinmeg
Star
I am able to block all media with that option. It is the content filter that seems to not be working like it should. I flip the media rule a d nothing works for streaming wise.
Message 3 of 5
Netduma-Liam
NetDuma Partner
Message 4 of 5
Steinmeg
Star
Going to accept this a a answer, it is a work around. We are 100% streaming so stopping media would stink. I will wait for a patch to block the specific websites, thank you for the information.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1965 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
