Discussion stats
  • 16 replies
  • 1352 views
  • 4 kudos
  • 4 in conversation
Announcements
Top Contributors
Reply
Highlighted
Star
Issues with XR450 and Destiny 2
I have the Nighthawk XR 450 firmware V2.3.2.40 and yes I have done the reset with all ethernet cords disconected.
I am having serious issues with destiny 2 for PC, I can play for about 15 minutes till I get disconnected from the router, have to unplug ethernet cord and replug to get connected back to the router. I have qos set for the specific ports, geofilter is correctly setup and not on strict mode and set to ps4. I have a netgear CM600 modem and I have verified that it is not causing the issue, I have zero issues if i plug straight to the modem but I need a router for other pc's and devices in the house.
My logs have alot of this
[DumaOS] DHCP lease change., Tuesday, July 02, 2019 17:33:20
[DumaOS] DHCP new event., Tuesday, July 02, 2019 17:33:20
[DumaOS] DHCP lease change., Tuesday, July 02, 2019 17:33:18
[DumaOS] DHCP new event., Tuesday, July 02, 2019 17:33:18
[DumaOS] DHCP lease change., Tuesday, July 02, 2019 17:33:06
[DumaOS] DHCP new event., Tuesday, July 02, 2019 17:33:06
and
[DumaOS] Error parsing line in ARP table: 'fe80::217:10ff:fe84:eddd dev brwan lladdr 00:17:10:84:ed:dd router STALE', Tuesday, July 02, 2019 17:33:11 [UPnP set event: del_nat_rule] from source 192.168.1.2, Tuesday, July 02, 2019 17:33:09
when the issue seems to happen I don't know if the 2 are related. Hope for some help because this is the only game I play and currently cannot play due to how the router is not performing. I'm pretty much at about the point of going and buying something else from elsewhere to find something that can work with the 1 game I play.
Message 1 of 17
Highlighted
Star
Re: Issues with XR450 and Destiny 2
I has now started happening even when I am not gaming that lease renew thing happens and I lose internet til I unplug my ethernet and plug it back in. I feel like whatever is happening is getting way worse and quick.
Message 2 of 17
Highlighted
Guru
Have you set a IP address reservation for your PC ON the router?
Is QoS enabled or disabled?
Is others using internet bandwidth when you gaming?
My Setup (Cable 900Mbps/50Mbps)>CAX80>Orbi RBK50 v2.5.1.16(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK50/RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 3 of 17
Highlighted
Star
Not sure on the ip address reservation, qos is enabled with all ports manually added for destiny 2 as priotized, no I am the only device that takes any bandwidth while gaming
Message 4 of 17
Highlighted
Star
Another thing that has me really thrown off is I had the router hooked up for about a month without any issues til last weekend when this started to happen. I had nothing setup or turned on as far a features go at that point and I didn't try configuring things until all of this started.
Message 5 of 17
Highlighted
NetDuma Partner
I don't know why the leases are renewing as often as they are... But one solution would be to set a reserved IP for your PC, here's how:
Open your router's interface (routerlogin.net), go to Settings > Setup > LAN Setup.
Scroll to the bottom and press Add under Address Reservation, select your device in the reservation table (hopefully it's named, if not, open cmd and use ipconfig) and then press Add.
Now the IP address won't change and hopefully the lease won't constantly renew.
Message 6 of 17
Highlighted
Star
I've done the reserved Ip played for about a hour no issues will report back in a couple of days and update.
Message 7 of 17
Highlighted
Star
Had no issues at all yesterday but woke up to this issue
It seems to be happening again even with the reserved ip
[DumaOS] DHCP new event., Friday, July 05, 2019 03:08:13
[DHCP IP: 192.168.1.2] to MAC address 60:45:cb:a0:d2:da, Friday, July 05, 2019 03:08:13
[DumaOS] DHCP lease change., Friday, July 05, 2019 03:08:10
[DumaOS] DHCP new event., Friday, July 05, 2019 03:08:10
[DHCP IP: 192.168.1.2] to MAC address 60:45:cb:a0:d2:da, Friday, July 05, 2019 03:08:10
[DumaOS] Error parsing line in ARP table: 'fe80::217:10ff:fe84:eddd dev brwan lladdr 00:17:10:84:ed:dd router STALE', Friday, July 05, 2019 03:08:08
[DumaOS] Error parsing line in ARP table: 'fe80::217:10ff:fe84:eddd dev brwan lladdr 00:17:10:84:ed:dd router STALE', Friday, July 05, 2019 03:07:51
[DumaOS] DHCP lease change., Friday, July 05, 2019 03:07:43
[DumaOS] DHCP new event., Friday, July 05, 2019 03:07:43
[DHCP IP: 192.168.1.2] to MAC address 60:45:cb:a0:d2:da, Friday, July 05, 2019 03:07:43
[DumaOS] DHCP lease change., Friday, July 05, 2019 03:07:19
[DumaOS] DHCP new event., Friday, July 05, 2019 03:07:19
[DHCP IP: 192.168.1.2] to MAC address 60:45:cb:a0:d2:da, Friday, July 05, 2019 03:07:19
[DumaOS] Error parsing line in ARP table: 'fe80::217:10ff:fe84:eddd dev brwan lladdr 00:17:10:84:ed:dd router STALE', Friday, July 05, 2019 03:07:19
[DumaOS] Error parsing line in ARP table: 'fe80::217:10ff:fe84:eddd dev brwan lladdr 00:17:10:84:ed:dd router STALE', Friday, July 05, 2019 03:07:16
[DumaOS] DHCP lease change., Friday, July 05, 2019 03:06:38
Message 8 of 17
Highlighted
NetDuma Partner
Could you try logging into your router and going to Settings > Advanced Settings > IPv6 and setting Internet Connection Type to Disabled.
Message 9 of 17
Highlighted
Star
I went to do that that but it seemed that was what it was already set at. I set it to that and clicked apply again just in case. still havthing the same issue though
log is filled with the
[DumaOS] DHCP lease change., Friday, July 05, 2019 10:29:54
[DumaOS] DHCP new event., Friday, July 05, 2019 10:29:54
[DHCP IP: 192.168.1.5] to MAC address e4:3e:d7:9d:8e:44, Friday, July 05, 2019 10:29:54
and this one seem to be paired always get them when it happens.
[DumaOS] Error parsing line in ARP table: 'fe80::217:10ff:fe84:eddd dev brwan lladdr 00:17:10:84:ed:dd router STALE', Friday, July 05, 2019 10:29:57
Is it possible that its just a bad router or something is corrupt in the firmware? seeing as the problem doesn't exist when that router isn't hooked up.
Message 10 of 17
Highlighted
NetDuma Partner
What is your ISP hub? Are you able to check its interface to see if when the issue happens it reports the router as offline?
Message 11 of 17
Highlighted
Star
By the ISP hub do you mean like the cable modem status or the isp status? If thats what you mean yes I can still log into my modem and all seems to be fine and correctly connected as far as I can tell, and its a netgear cm600 so its not one the isp provided ones and its only about 2 months old same as the router. I haven't had anymore issues since I got off of work today so I dunno. I switched to all new ethernet cables today just to eliminate that as a issue as well as added some additional cooling to the shelf the modem and router are on via a usb fan.
Message 12 of 17
Highlighted
NetDuma Partner
Yes I meant the ISP modem, okay that's good, fingers crossed what you've done sorts it, do keep us updated. If it happens again access the modem interface and see if it's showing the router as connected to the internet or not.
Message 13 of 17
Highlighted
Star
Will do,Thanks again for all the tips and advice!
Message 14 of 17
Highlighted
Star
So all has been pretty much well as far as things go but today this happened and kicked me offline it was doing this same dos attack for about an hour before I could get back online according to the logs(I just pasted a section seeing as it was the same thing for about 2 hours in the logs. Now is this just noise or am I actually being targeted seeing as how when it stopped my internet started working again.
[Internet connected] IP address: 24.168.221.113, Tuesday, July 09, 2019 19:55:02
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:49
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:48
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:47
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:46
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:45
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:44
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:33
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:30
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:28
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:22
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:21
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:20
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:19
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:17
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:16
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:15
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:14
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:13
[DoS Attack: ARP Attack] from source: 24.168.192.1, Tuesday, July 09, 2019 19:43:06
Message 15 of 17
Highlighted
NetDuma Partner
Well the two IP addresses there are from Spectrum/Charter Communications so that doesn't jump out as being targeted but then again it could be an individual with that ISP. It might be worth phoning your ISP and asking them if there was anything strange going on in the time frame when it happened and give them the IPs.
Message 16 of 17
Highlighted
Star
If it happens again, I'll phone them, I sometimes suspect that it might just be their backend "system keeping the flow of data fair" of just plain kicking me offline because I am more then likely the highest bandwidth consumer on the road.
Message 17 of 17
