- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issues with XR700 after a few days uptime
- Mark as New
- Bookmark
- Subscribe
- Permalink
I posted this in the NetDuma website as well. I'm having issues after a few days of uptime on the router (XR700). Here is the link with pictures of the issues.
https://forum.netduma.com/topic/29779-new-firmware-for-xr700-issues/?do=findComment&comment=244043
Please get back to me with any thoughts. Thank you for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issues with XR700 after a few days uptime
Upgrade to this firmware and then do a factory reset and it should fix the issue: https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix
- Mark as New
- Bookmark
- Subscribe
- Permalink
No this new FW did not fix the issue. I updated the FW, did a hard 60 sec reset and configured manually (not from file). I opened up the admin GUI and get "This R-App is not loaded yet, please try again in a minute." on the dashboard after a short period of time. The issue doesn't go away and the messages keep coming back (the apps just don't re-start themselves) Same issues as before after a short test (going through the admin GUI and testing wireless bands). A reboot of the unit does allievate some issues (Apps not Wireless). It's a shame really, this router used to be pretty solid. What's going on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Screenshot of it still being poop in Chrome. I was thinking I'm pretty sure if an app doesn't work in MSE it wouldn't work in Chrome as the app isn't loaded (or responding). That's not a browser issue that's a issue within the OS on the router. Also the browser wouldn't have anything to do with WiFi issues. Here's another screenshot for you in Chrome though if that helps ease your mind. These are expensive routers, this FW issue(s) shouldn't happen for a $500 piece of routing equipment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes we have a Nintendo Switch. We have a PS4 Pro, Xbox One, Nintendo Switch, Nintendo 3DS's (2), tablets, PC's, Laptops, Phones, Roku's, IP Cameras, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's another pic.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well I'm glad you've isolated the issue, but it's not a PS or Xbox so you should really fix that issue with the Nintendo Switch instead of just dumping it onto a PS or Xbox config for QoS. I'll let you know if I experience more app drops.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just logged in to the admin GUI and your DumaOS apps are still screwed up. Hope you've got it figured out. I'm on that beta FW, did the hard reset, manually configured settings and not restored from backup file, changed the Nintendo Switch to an Xbox in Device Manager and it's still poop. Hope the screen shot helped but I know it doesn't really.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So you suggest just doing everything you told me again. And replace what the $500 router I purchased specifically because of your company's OS on it??? Is that really your professional stand? If so sure I'll replace it when you buy this POS back. This is pretty garbage support on such an expensive router, Fraser. I'd expect more from a company after purchasing their flagship unit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I mean I get that I really do. The NetDuma team should be all over it though honestly I mean that's their name on it ya know, more so than Netgear and the fact their apps stop responding means it's on their end not Netgear as the basic functionality of the unit is pretty sound. I'll stick it out because like I said this is the flagship for now and I don't really feel like sitting on a $500 paperweight and replace it with another brand when they won't offer the tools that DumaOS do. The FW was so sound I mean it was rock solid until what the .21 update then it just went to poopy pie. Js man. Anyway light a fire under them for me and tell them I'm dying over here!
- Mark as New
- Bookmark
- Subscribe
- Permalink
As a suggestion, you might downgrade to last working version of FW prior to v20.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah I mean if you're making changes to the apps themselves then any issues they had would be eliminated because you're changing the apps and they will be THOROUGHLY TESTED TO MAKE SURE THEY DON'T STOP RESPONDING AFTER DAYS OF LOAD right? lol I mean if it's a total overhaul of the Rapp system then yeah should be fine. Just make sure it's passes the quality control before released in beta.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same thing's happening to me and I have to say, I'm not too happy paying through the nose for something that is supposed to be flagship material. I upgraded from an earlier version of the Netgear Nighthawk (R7000). I didn't have any issues with the old unit and miss it's reliability. The IOS app that can be used to access the XR700 is the same app that I used to use to access the R7000. Half the features in the app don't work with the XR700.
I really hope you get these issues sorted out in the next release but for now, I'm replacing the XR700 with my old R7000.
Not happy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
