× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Lost traffic prioritization after update xr500
Morty_774_
I updated my router yesterday and since then I’ve lost the traffic prioritization box on the QOS page? Any ideas why? Thanks.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 40
Guru
Re: Lost traffic prioritization after update xr500
Have you tried a factory reset?
Message 2 of 40
Morty_774_
I did reset after firmware update but will try again.
Message 3 of 40
Guru
what firmware version did you update to?
Message 4 of 40
Morty_774_
V2.3.2.120 duma
Message 5 of 40
Netduma-Fraser
NetDuma Partner
Give the router a reboot from the interface and then it should load correctly
Message 6 of 40
paul5680
Please help me I'm having the same thing happen to me now
Message 7 of 40
Netduma-Fraser
NetDuma Partner
@paul5680 reboot from the interface, wait 2 minutes then access the router and it should load correctly.
Message 8 of 40
paul5680
I did and nothing please help
Message 9 of 40
Netduma-Liam
NetDuma Partner
Is this after upgrading firmware? If so, please make sure you've factory reset the XR.
Message 10 of 40
paul5680
I have done a factory set twice It still does not work please help It still does not work please help And this is showing up
Message 11 of 40
paul5680
I'm still have the same thing happen please help me
Message 12 of 40
Netduma-Liam
NetDuma Partner
You can ignore those entries in the logs, they're mainly there for devs to look at if there's a problem. While the entries you're seeing may seem sinister, they're nothing to worry about.
Are you still having issues with Traffic Prioritisation loading? Can you send a screenshot of what you're seeing now?
Message 13 of 40
CyBer82
Guide
It's all up2date with me, but the router has been crazy for days, I did renew and a lot more, now I'm at the end of my knowledge.
Message 14 of 40
Netduma-Liam
NetDuma Partner
What's the problem you're having exactly? There's nothing out of the ordinary in the logs that you've provided.
Message 15 of 40
CyBer82
Guide
connection problems micro-exposed
[DumaOS] DHCP new event., Friday, November 26, 2021 09:46:43
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:46:43
[DumaOS] DHCP new event., Friday, November 26, 2021 09:46:48
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:46:48
[DumaOS] DHCP new event., Friday, November 26, 2021 09:49:56
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:49:56
[DumaOS] DHCP new event., Friday, November 26, 2021 09:50:12
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:50:12
[DumaOS] DHCP new event., Friday, November 26, 2021 09:50:26
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:50:26
[DumaOS] DHCP new event., Friday, November 26, 2021 09:50:52
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:50:52
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:05
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:05
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:28
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:28
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:34
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:34
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:42
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:42
[DumaOS] DHCP new event., Friday, November 26, 2021 09:54:27
[DumaOS] DHCP new lease allocated., Friday, November 26, 2021 09:54:27
Message 16 of 40
Netduma-Liam
NetDuma Partner
If you reserve an IP address for each device that appears to be losing connectivity, does the problem continue and do you still see the same entries in the logs?
Message 17 of 40
CyBer82
Guide
its the same 5time to factory , back flash firmware und install via router
FirmwareversionDumaOS-Version
V2.3.2.130
3.0.202
same Problems
Message 18 of 40
CyBer82
Guide
I'll let it go, I'll get back to you with a new log in two hours
Message 19 of 40
CyBer82
Guide
all fine now,,,,, after 5th factory downgrad und Update via dumaos install assi.
Message 20 of 40
paul5680
I can take a picture when I get off from work at 6am Saturday morning. When I'm in QOS the traffic just spins nothing load under traffic prioritizing tab
Message 21 of 40
paul5680
I can take a picture when I get off from work at 6am Saturday morning. When I'm in QOS the traffic just spins nothing load under traffic prioritizing tab. Now my DNS says 8.8.8.8
Message 22 of 40
Netduma-Fraser
NetDuma Partner
I think you'll need to downgrade then upgrade again and don't do a reset and it should load
Message 23 of 40
CyBer82
Guide
the same mess again after a few days what did you do with the 130, I'm really fed up with being an alpha tester. last chance before I send the part back and buy a Cisco
LOG :[DumaOS] DHCP new event., Tuesday, November 30, 2021 08:15:32
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 08:15:32
[DumaOS] Cloudsync Themes result 'false','All mirrors are down', Tuesday, November 30, 2021 08:35:28
[DumaOS] Theme path does match manifest 'default', Tuesday, November 30, 2021 08:35:28
[DumaOS] The selected theme does not exist: 'default', Tuesday, November 30, 2021 08:35:28
[DoS Attack: SYN/ACK Scan] from source: 95.217.31.46, port 443, Tuesday, November 30, 2021 08:37:26
[DumaOS] DHCP new event., Tuesday, November 30, 2021 08:46:21
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 08:46:22
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:15:52
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:15:52
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:20:51
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:20:51
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:21:01
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:21:01
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Tuesday, November 30, 2021 09:21:07
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Tuesday, November 30, 2021 09:21:07
[DumaOS] recovering state com.netdumasoftware.dpiclass, Tuesday, November 30, 2021 09:21:10
[DumaOS] Cloudsync DPI result 'true','nil', Tuesday, November 30, 2021 09:21:12
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Tuesday, November 30, 2021 09:21:13
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Tuesday, November 30, 2021 09:21:13
[DumaOS] recovering state com.netdumasoftware.dpiclass, Tuesday, November 30, 2021 09:21:13
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:21:33
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:21:33
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:22:01
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:22:01
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:22:04
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:22:04
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:26:36
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:26:36
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:27:27
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:42
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:43
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:44
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:45
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:46
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:47
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:48
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:49
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:50
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:51
Message 24 of 40
Netduma-Liam
NetDuma Partner
Do you still have the original IP reservations setup that you did previously? If not, that's likely why you're experiencing the issue again.
Message 25 of 40
Discussion stats
  • 39 replies
  • 4023 views
  • 2 kudos
  • 6 in conversation
Announcements
Orbi 770 Series
