- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Mac filtering issue XR1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I'm trying to connect a new Epson printer via WiFi to the network and it seems that every 1 min it gets disconnected for a few seconds and comes back up after.
I managed to get an error from the printer and it says that the problem is with MAC filtering from the router side, but I can't find any related setting on the XR1000 router ( I even reserved specific IP for this printer - still no go)
Can you advise on how can I proceed to fix it?
Info:
Firmware Version 1.0.0.64_1.0.49
DumaOS Version 3.1.1
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Mac filtering issue XR1000
Yes, I'm using Smart Connect - it appears your advice was correct. When I disabled SC - the printer started to work like a charm.
Is this will be fixed on the next firmware upgrade? For me, using SC over 2 different networks (2.4 and GHz) is better.
Or is this problem with the printer side and should I ask Epson support about this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would be on the printer side of it not being able to connect with SC is enabled. The router provides the platform to connect too. It's up to the connecting devices to pick and choose there they connect. If they don't have dual band support then they should connect to the 2.4Ghz radio with out problems. Some seem to have problems with SC though.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Another option would be to ethernet connect the printer to the router...If it has a ethernet port.
