- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Moderate Nat type in warzone with XR500
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi i have a moderate nat type in warzone but my ps5 has an open nat type 2, my xr500 is connected to my bt homehub and is in its DMZ, ive tried portforwarding the game ports, ive tried putting nat filtering to open on my XR500, i have also put my console in the DMZ of the XR500, could it be an issue with my running 2 routers? And anything else i could try that may help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Moderate Nat type in warzone with XR500
The issue may simply be that you have all of those settings enabled at once. I would suggest removing port forwarding rules and remove you console from the XR DMZ. Disable UPnP such that you only have the XR in the BT DMZ, I'd also suggest setting a static IP to the XR while you're there. Once this is all done, reboot both router and then boot your PS5 and check you NAT type.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
