× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
NAT Filtering is making me have less than half of my ISP Download speed
iAmazing
Tutor
My XR300 when i put him in NAT Filtering: Open, my download that are 500mbps go to 150mbps. Anybody knows why?
I need it open because i play games like Call of Duty and i need Nat: Open and not Strick...
When i put NAT Filtering back to "Secured" the download speeds go back to normal.
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 4
Netduma-Fraser
NetDuma Partner
Re: NAT Filtering is making me have less than half of my ISP Download speed
It shouldn't affect that at all but are you not able to get an Open NAT using UPnP? An alternative would be to just put the console in the DMZ instead.
Message 2 of 4
iAmazing
Tutor
I already did that. i DMZ the console and i m using UPNP, but still if i dont open the NAT PS4 says NAT type: STRICT
Model: A6100|WiFi USB Mini Adapter, XR300|Nighthawk Pro Gaming Router
Message 3 of 4
Netduma-Fraser
NetDuma Partner
Are you reading the NAT from the game itself or the console network settings? What does it say in the console network settings? Is your XR in the DMZ of your ISP router?
Message 4 of 4
Discussion stats
  • 3 replies
  • 4140 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
