× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
NETGEAR Nighthawk Pro Gaming XR500 stopped working midway through a Zoom meeting
Druba
The router unexpectedly stopped working. The power light is blinking white slowly; sometimes, it's just fully red. No other lights are on in any capacity.
Message 1 of 6
Guru
Re: NETGEAR Nighthawk Pro Gaming XR500 stopped working midway through a Zoom meeting
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Can you access the routers web page at all?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Factory reset and setup from scratch with the Router disconnected from everything including the ISP modem.
Press the reset button for 15 seconds then release. Give 2 minutes and see if you can access the routers web page at 192.168.1.1
Message 2 of 6
Netduma-Fraser
NetDuma Partner
Good advice above. Could have been some sort of power fluctuation
Message 3 of 6
Druba
I can't access the router's webpage.
I have a Motorola MB8600. I've been using the cable that came with the router for the past 3-4 years.
I've tried unplugging for 20 minutes, and replugging to no avail.
I've tried manually uploading firmware through cmd, but the connect request failed.
I just tried the sequence you detailed but that didn't work either sadly.
Message 4 of 6
Guru
Last thing to try is a 30-30-30 reset. IF this fails to bring back the XR router to a setup state at 192.168.1.1 then router probably needs to be replaced.
Message 5 of 6
Netduma-Fraser
NetDuma Partner
Do you have it connected to a power extender or direct to an outlet? If an extender please try direct to an outlet. Otherwise do you have another power adapter you could try with?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1392 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
