× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
NETGEAR XR1000; Location
TypicalSwab
Hi,
I've recently moved in to another Property (8 days here) and have connected my XR1000 to the existing Modem/ISP here.
If I use Google Maps to identify my location on my PC, it shows me a pin about 58 mins drive from where I am.
If I use my iPhone, connected to the WiFi, Google Maps and other Apps locate me at my old address.
Just wondering what I can do to fix this.
Thanks
Message 1 of 6
Netduma-Liam
NetDuma Partner
Re: NETGEAR XR1000; Location
If you connect your PC/Mobile device directly to your ISP router/modem, do you still observe the same behaviour?
Message 2 of 6
TypicalSwab
Thanks for getting back to me.
I've just tried this and no, the behaviour doesn't apply if connected directly to the ISP's router.
Message 3 of 6
Netduma-Fraser
NetDuma Partner
Have you got your PC added to the Geo-Filter?
Message 4 of 6
TypicalSwab
No I do not.
Message 5 of 6
Netduma-Fraser
NetDuma Partner
If you type my location into Google search engine does it show correctly? Do it connected direct to the modem as well, do you get a different result?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 988 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
