× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
NIGHTHAWK XR 500 XBOX ONE
NINA73
Hi
Just after getting the Nighthawk XR500 and trying to set it up for all our consoles. PS5 set up fine and is downloaded no problem, Xbox one will connect but not download anything
PS4 will not connect at all.
Probably something simple I need to do but unsure of how to solve it any advice appreciated.
Also trying to set up the amazon echo and cannot either it keeps stating password incorrect if anyone has come accross this issue and were able to resolve it?
Thanks
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 10
Netduma-Liam
NetDuma Partner
Re: NIGHTHAWK XR 500 XBOX ONE
Thanks for posting!
How are the consoles connected? Via wired or wireless?
Are the problematic consoles showing up in Device Manager on DumaOS?
Are any other network devices struggling to get connected besides the Echo?
Have you double check the password listed in the DumaOS Network Settings is the same as the one you're entering in the Echo setup?
Message 2 of 10
NINA73
PS5 is wired others wireless, yes all showing up on the device manager, all phones and other devices are connecting no problem echo just wont connect and the xbox one will not download games etc we were able to stream netflix but not download games .
Message 3 of 10
Netduma-Liam
NetDuma Partner
That's interesting, have you made any changes to the Wireless settings on the XR500? Do you have Smart Connect enabled or are the 2.4 and 5GHz networks seperated?
Message 4 of 10
NINA73
smart connect is enabled,
Message 5 of 10
Netduma-Fraser
NetDuma Partner
Disable Smart Connect and try connecting them manually to 2.4GHz and see if it works please. Do the consoles complete a network settings test successfully?
Message 6 of 10
NINA73
the xbox does the test fine but does not give a download speed but states connected to xbox live the ps4 will not run the whole network test connection it fails early on I iwll run again and get the exact problem area with it
and we tried with the net gear 5g with the echo device will try with the 2.4  and let you know thanks for help
Message 7 of 10
Netduma-Fraser
NetDuma Partner
Are you trying to connect them with manual network settings or leaving it as automatic?
Message 8 of 10
NINA73
Leaving it automatic
Message 9 of 10
Netduma-Fraser
NetDuma Partner
Any luck with 2.4GHz?
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3059 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
