× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Need some expert networking opinion. XR500 with FIOS G1100 and Eero
Xenecus
I'm trying to get the best out of the XR500 router without losing my eero wifi network and all working with the Fios Gateway G1100
What I want to do is have the XR500 as the main router and bridge my FIOS router but somehow keep my eero for all wifi devices.
Is there a way to have two different networks? or is the recommended setup here to bridge my FIOS and Eero and have the XR500 as the main router?
I only need the XR500 to handle wired connections to my office and my media room, eero will be handling all of the wifi within the main floors of the house.... the FIOS router is only there for TV services.
I'm not sure exactly what the best approach is here.... any assistance will be greatly appreciated it
Message 1 of 6
Guru
Re: Need some expert networking opinion. XR500 with FIOS G1100 and Eero
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
Then you want the EERO as your wifi source, I would disable the wifi on the XR router and set up your EERO for LAN to LAN AP mode if it supports that configuration.
Message 2 of 6
Netduma-Fraser
NetDuma Partner
Probably the best bet here is to put the FIOS in bridge mode to the XR500. Completely disable the XR500 WiFi and connect the Eero to the XR500. I think that would achieve what you want
Message 3 of 6
Xenecus
@FURRYe38 wrote:
Modem Combo Units:
sorry for the noob question, but what would this achieve ?
Message 4 of 6
Netduma-Fraser
NetDuma Partner
It would ensure all port traffic goes straight through to the Netgear. This would ensure you wouldn't get double NAT
Message 5 of 6
Guru
What Fraser said. Single NAT condition is always perferred for gaming.
http://computer.howstuffworks.com/nat.htm
http://www.practicallynetworked.com/networking/fixing_double_nat.htm
http://www.dslreports.com/shownews/Networking-101-The-DMZ-137550
@Xenecus wrote:
@FURRYe38 wrote:
Modem Combo Units:
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2160 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
