× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
NetGear Router - Device Manager - Un Named Device
pbudreski
Tutor
Hello
I spent sometime with the Device Manager identifying known devices on the NetGear XR 1000. Subsequent to the preparation of an accurate list that reflects what devices on site, an un named device has appeared.
Any tips on how to identify this device & delete it?
Message 1 of 3
Accepted Solutions
Guru
Re: NetGear Router - Device Manager - Un Named Device
do you use any apple or android devices that are using private mac/ip address? If so, they can show up unknown
Message 2 of 3
All Replies
Guru
Message 2 of 3
Netduma-Fraser
NetDuma Partner
The above is a very good point, that could be it. Otherwise if you copy the MAC address then google MAC lookup vendor you can enter the MAC address and it will tell you the manufacturer and you might be able to work it out that way.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 583 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
