× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netduma Settings
Wyzfar
Netduma Settings
Hello so i have two Netduma Routers this might seem like an odd setup that i am trying to complete but i am curious can i have my XR500 Handle WiFi devices and have my other DumaOS Router for just my LAN Devices only ? the reason i want to accomplish this is because i would like to distribute a set amount of bandwith to my LAN  devices so that when a new device connects to the router handling the WiFi devices it does not interfere with the set bandwith to my LAN devices.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Liam
NetDuma Partner
Re: Netduma Settings
You could simply put your XR500 into AP mode from it's settings? This means you could use it as a Wi-Fi extender of your other router.
Message 2 of 2
Discussion stats
  • 1 reply
  • 719 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
