×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Netgear Night hawk xr700 speed issues
Jayappa
Tutor
Hey everyone, I got a Night Hawk XR700 a week ago and having speed issues through the lan port. I’m convinced it’s a hardware issue or a software issue because I did multiple tests and searched the whole internet for this unsolved problem. I have 100 speed using the lan port on the test is shows that but when I complete the setup my wired connections go from 100 to 10. My WiFi are normal though and work fine. I disabled QOS, and BUFFER BLOAT and tried different variations of this. I also want to mention that the setup page takes insanely long to load and took me 2 hours to setup. If any admin or anyone at this point help me could you take a couple mins out if your day to help out
-Thanks
-Jay
Model: XR700|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Fraser
NetDuma Partner
Re: Netgear Night hawk xr700 speed issues
What is your exact physical setup? Are all devices connected to the XR? Do the LAN ports appear with Amber/orange lights on the router? How did you disable QoS?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 659 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
