× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk 1900 Dropping Internet connectivity
jakethomas08
Ok so I have a Netgear Nighthawk AC1900 router
I have recently had multiple issues with this router dropping the internet connection but still showing connected on most devices. This happened very shortly after the warenty expired, very surprising..........
I initially would reset the entire system (Modem and Router) when this happened occasionally and that would fix the problem. But it apears since the latest firmeware version came out (July) it has been dropping frequently. It has gotten worse now to every hour or so.
I have done quite a bit of troubleshooting most of the things I've tried are listed below:
Hardwire to the Modem - Successful
Hardwire to the Router - Successful
Connected to 2.4 band - issues
Connected to 5 band - issues
Updated router firmware- issues
Reverted the router firmware - issues
Backed up settings and restored router - issues
Changed the channel on both the 2.4 and 5 wifi - issues (possible improvement but still dropping)
Please let me know if there is something else I can try other than getting another router.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
Guru
Re: Netgear Nighthawk 1900 Dropping Internet connectivity
AC1900 is a speed, not a model.
Which router do you have?
What firmware is on it? (please don't say the latest)
What modem is it connected to?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 590 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
