× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk extender with Ethernet input
KAWB
Follower
Hi all,
Hoping someone can give me a simple answer.
I have installed the RAX20 Nighthawk Router.
I need new wifi range extenders.  I have Ethernet running into most rooms in the house (it's a large house)
I'm wondering if there is any extenders with Ethernet input, that I can put around the house that is easily compatible via the app.
I'm not very tech savvy so hoping I worded that ok.
Thanks so much
Message 1 of 3
Guru
Re: Netgear Nighthawk extender with Ethernet input
many of netgears extenders have access point mode. thats basically what you're looking for. Some of the very base models like the ex2700 don't have access point mode but if you search through the extenders on netgears site and pick the one you want, then just check to see if thats an option for it.
Or you can even use a router and run it in access point mode.
Message 2 of 3
Guru
Please post about this over in the RAX forum:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
or the WiFi Extender forum:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Good Luck.
@KAWB wrote:
Hi all,
Thanks so much
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 832 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
