×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Netgear XR1000 - Using Bridge Mode
dpl001
Initiate
Hello,
Recently changed broadband providers and got a modem/router that can use bridge mode. However whenever I put it into bridge mode via the modems gateway, I'm unable to get internet on to my Netgear. I initially get all three white lights confirming I have internet access but when I actually then connect to the Netgear router, it kicks me off of the network and when I reconnect, I'm unable to get internet. I have connected the modem to Netgear router via ethernet cable.
After putting the modem into bridge mode, I have turned on/off both equipment.
Any help would be appreciated.
Thanks,
Message 1 of 3
Guru
Re: Netgear XR1000 - Using Bridge Mode
Try leaving it (the providers modem/router) in router mode and disable its wifi. Then put the netgears IP address into its dmz. That should accomplish the same thing
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
dpl001
Initiate
Thank you. Seems to have worked and the NAT seems to be staying open.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 591 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
