- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear XR500 intermittent connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have recently moved to a property that has PPPOE broadband. I originally made a custom size CAT6 cable to route to my office with the router staying close to the modem. However since installation there's been nothing but internet issues. I can do a speed test on a browser (after it loads), it takes a few minutes to complete and says I'm receiving the speeds I pay for (900mbps UP/DOWN). Rarely does a webpage load first time on my PC (hardwired). I have tested the cable and its fine however changed to a different cable and the issue persists. I am curious if my router just isn't up to spec anymore however I'd rather not fault find by just spending money on new gear. Also wifi range is very poor. Not normal for when I last used the router a few years ago.
Router Reset, Up to date firmware, CAT6 Cable change.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear XR500 intermittent connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
v2.3.2.134
And it's Fibre so it's a box on the wall that it goes to, I have no way on knowing that other bit to fully answer your question sorry.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
Possible this maybe a ISP issue. I'd have the ISP have a look into there system up to the ONT.
Did you try the beta from NetDuma yet?
@NathanXR500 wrote:
When I changed the DNS it didn’t improve anything it’s so intermittent, on second the page won’t load then you reload it and it does sometimes it doesn’t. I changed it from the ISP to Google DNS FYI
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
