Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear XR500 vpn reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-05
08:20 AM
2020-03-05
08:20 AM
Hello,
I have a question regarding my XR500. i've had some problems because i couldn't connect trough tunnelblick to my vpn.
Now have i asked a friend for help and it was solved but he hase the config file to connect to my vpn aswell since we where testing if he could connect. is there a way to reset this file to have a new client.conf and ca.crt made?
Kind regards,
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-05
11:01 AM
2020-03-05
11:01 AM
Re: Netgear XR500 vpn reset
You're using the VPN service correct? The only way to 'reset' the config so that the one they have doesn't work anymore would be to change the service ports or modes and then apply and download the new config. You would then have to reflect this change on your client.
Message 2 of 2
Announcements
