Reply
Highlighted
Netgear XR700 Sluggish Performance and Losing WAN
Having a few issues with the router done the same test with a R7000 with Merlin  WRT and there are no issues..
Is this expected performance fto 100% cpu from a xr700 downloading a single torrent file?
This usually ends up with a locked router admin page and a reboot is required.
On Latest firmware and done factory reset.
Model: XR700|Nighthawk Pro Gaming Router
Message 1 of 11
Highlighted
NetDuma Partner
Re: Netgear XR700 Sluggish Performance and Losing WAN
This sounds like something you might need to contact NETGEAR support about. This router should be able to handle much more than you're throwing at it here.
Message 2 of 11
Highlighted
Guru
Try downgrading FW to 1.0.0.20
FYI, (x)WRT is not supported on the R7000...So test comparison isn't really valid.
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 3 of 11
Highlighted
NetDuma Partner
On your torrent client could you disable uTp please and redo the test, does it work correctly then?
Message 4 of 11
Highlighted
This is the version of XWRT i have installed
http://xvtx.ru/xwrt/about.htm
And it does support the r7000!
Message 5 of 11
Highlighted
Hi Fraser,
On my client it I dont have uTp but i do have DHT is that the same??
Message 6 of 11
Highlighted
NetDuma Partner
No DHT is to do with Torrents that don't have a single tracker. I'd probably leave this enabled.
UTP is a uTorrent feature that slows down your torrents so that they don't interrupt your other networking activities.
But for the sake of the test you should disable it so that you get the maximum speeds.
If you don't have UTP then don't worry.
Message 7 of 11
Highlighted
My connection is ADSL 300mb Gfast UK with a  Huawei MT992 modem
Message 8 of 11
Highlighted
NetDuma Partner
Would you be able to try with an alternate torrent program such as Bittorrent, disable uTp and see if you have the same experience?
Message 9 of 11
Highlighted
I flashed the firmware via TFTP and since that flash all has been good.
Message 10 of 11
Highlighted
NetDuma Partner
Great to hear that, thanks for the update!
Message 11 of 11
Discussion stats
  • 10 replies
  • 1034 views
  • 2 kudos
  • 4 in conversation
Announcements
